Turn Signal Canceling Failure Fix: Lots of Pics
Old 05-08-2015, 04:14 PM
  #51
vogtrj's Avatar
Brilliant! Thank you for the great write up and pictures.
After playing for a couple minutes to get one part right, it went together with the spring going the right way and works like a champ.
I love this forum.
vogtrj is offline
Old 07-22-2015, 11:01 PM
  #52
SwiftLikeNinjas's Avatar
I'm so glad I found this thread!
Mine went out last weekend, right after my husband replaced the clockspring. Naturally, I assumed he accidentally broke it; as I had accidentally broken the clockspring. (Apparently, turning a disconnected steering wheel around and around is not a good idea. Woops!)
Anyways, I'm going to try to fix it tomorrow. It seems like a very simple fix for such an annoying problem.
& my husband will be happy to save a few bucks as well!
SwiftLikeNinjas is offline
Old 08-05-2015, 12:12 PM
  #53
MikeRuth's Avatar
Mine is broken...
First off kudos to all of you who posted about how to do this fix.
Mine did not work at all so I removed it this morning in just a few minutes knowing how from this thread. After reversing my spring I noticed the cam plate would not center and that's when I discovered that the cam plate had broken.
so I'll have to hunt one down, maybe Junkyard or a non OEM.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
MikeRuth is offline
Old 08-05-2015, 01:01 PM
  #54
Technical Moderator
Is there something wrong with eBay?
It's pretty much a basic part. NAPA may even have them.
donbrew is offline
Old 08-05-2015, 02:57 PM
  #55
MikeRuth's Avatar
ACDelco D6254E GM Original Equipment Turn Signal and Headlamp Dimmer Switch
Nope nuttin wrong with either, but I'm happy with this and free shipping at the Amazon
Amazon.com: ACDelco D6254E GM Original Equipment Turn Signal and Headlamp Dimmer Switch: Automotive Amazon.com: ACDelco D6254E GM Original Equipment Turn Signal and Headlamp Dimmer Switch: Automotive
$27.11 to my door in two days.
MikeRuth is offline
Old 08-06-2015, 08:56 AM
  #56
That's the one I got when mine malfunctioned, been working fine ever since, about 2 years now!
Oldblue is online now
Old 10-04-2015, 08:45 AM
  #57
delhooters's Avatar
Replacement switch
Judging from some of the Amazon reviews (apparently some people return their broken part as the original that they decided they didn't want, so I went with Rockauto. About the same price too.
delhooters is offline
Old 10-05-2015, 07:20 AM
  #58
Lee3333's Avatar
Many years ago, when I swapped my steering wheel for a smaller one, I recall a piece on the left side of the hub falling off. Ever since, my lights don't cancel. But I have learned to prefer it this way. They used to shut off when I turned the wheel a little to change lanes before making a turn, and once I forgot to put the signal back on and got pulled over.
Now, I turn them off when I want to. And, there is a feature on our cars that will notify you if you leave the turn signal on too long.
Lee3333 is offline
Old 01-27-2016, 06:50 PM
  #59
RatRodS's Avatar
Thanks for the write up. Just replaced the wiper switch, the symbols had faded and it wouldn't cancel.
RatRodS is offline
Old 07-21-2016, 11:15 AM
  #60
Beachbum1's Avatar
My '07 HHR with 113K miles finally had the dreaded turn signal cancel fail. How great is it to already know the problem & solution because we belong to the best car forum anywhere!
I did order a new one from Rock Auto less than $30 delivered. Just finished replacing it after looking at Snowhites pic's, took less an an hour. I will now repair the old one for a spare.
Thanks again to CHEVHHR.NETsaved me big money & a trip to the dealer.
Beachbum1 is offline
Quick Reply: Turn Signal Canceling Failure Fix: Lots of Pics
