What do I do now, I have a Check Engine Light
Old 01-16-2015, 05:55 PM
Technical Moderator
Post What do I do now, I have a Check Engine Light
How to research OBD2 codes
Okay you had a "Check Engine Light", somebody told you to go to Advance Auto or O'Reilly's or some other auto parts store to get the codes read. What do you do after you get the code NUMBER?
Do not listen to the sales clerk after they give you the number. You don't even want to hear the name or description of the code! Just the NUMBER, it will probably start with a P and they usually say "O" instead of "0". The only letter involved will be the leading one all engine codes start with a "P" the xxxx. Write it or them down. (some codes will have a letter far the last digit; the codes are actually a scientific notation octal I think)
First: put the number into Google, then follow a few of the links presented. This will give you a feeling for what is going on.
Second: put the number into the ChevyHHR.net search box, then follow a few links.
Third: If you have gotten yourself a bit educated about what is going on and want to know exactly what the codes mean. Go to :https://gsitlc.ext.gm.com/gmspo/mode6/index.html. The information contained on this site can be dangerous if you don't understand the systems involved. It is one of those "too much information" things, but explains exactly what the computer is doing.
(you want to look at the GM CAN - GM Powertrain section under Mode 6 Data, and your year under Engine/Transmission, then look at the "Engine & Transmission Diagnostic Parameter File Matrix" to find which PDF file applies to your car.)
donbrew is offline
Old 01-16-2015, 09:22 PM
Good find and post Donbrew!!!
whopper is offline
Old 01-17-2015, 12:32 AM
843de is offline
Old 01-18-2015, 05:10 PM
Awesome Don!!
Now make it sticky!!
or maybe I suggest this be designated a sticky
Oldblue is online now
Old 01-18-2015, 06:54 PM
Technical Moderator
Already is a sticky.
donbrew is offline
Old 01-18-2015, 07:06 PM
Oh, didn't see that! Thanks again Don!
Old 03-05-2015, 09:14 PM
Wheatgerm's Avatar
Good Stuff, Thank You. Getting Educated already once again..
Wheatgerm is offline
Old 04-06-2015, 07:44 AM
papa_jo's Avatar
getting to edumacated!!! looking at stuff I have never seen gives me a head ache unless it is a good looking woman
lol
papa_jo is offline
Old 07-12-2018, 07:24 AM
cturboaddict's Avatar
Link no longer works.
cturboaddict is offline
Old 07-12-2018, 08:07 AM
Technical Moderator
Link fixed https://gsi.ext.gm.com/gmspo/mode6/index.html
donbrew is offline
Quick Reply: What do I do now, I have a Check Engine Light
