Passenger Floor Soaked/Moonroof Drain FIXED
This is my first post and I have been a member for less than a week. I have owned two 2008 HHR LS models in the past and really enjoyed both. I didn't even know the SS model existed until I started searching for another vehicle. Picked up a 2008, 5 speed with 76,000. Really like the car and definitely a little more performance than my other HHR's.
I towed it home on a U Haul transport and it rained all the way from the dealer to home about 240 miles. Then rained all night here. I discovered the passenger floor board soaked the next morning when I went to unload from the trailer. I thought maybe I hadn't shut the door. Vacuumed the water up and dried carpet out. Thought it was good.
Then yesterday we had a heavy rain and afterwards discovered the floor soaked again. Thanks to all of you and post about floor boards being wet. As I said mine is a 2008 so I just breezed through the post about 2006 models and their issue with leaks. I was told by the dealer they had to have the moonroof motor replaced so I read the post about the moonroof drains. Long story short, the front drain tube was not connected on the passenger side. Thank you!
Also knew about the clunking the HHR's seem to have in common up front but didn't know why. Read post about the. Linking and his to fix, so ordered new MOOG anti sway bar links. Thank you again.
I apologize for a long post but wanted to give a little history and most importantly say thank you.
Dave
Dave
Last edited by RJ_RS_SS_350; 03-22-2017 at 09:14 PM. Reason: Added a few spaces for easier reading
front end clunks are mostly caused by bad sway bar bushings or lower control arm bushings or sway bar links , as for the wet floor u need to pull the wiper arms pull the black cowl cover and u should find that the pass side hole cover has failed or the seam lifted and is letting water into the heater box and is flooding the floor it will also cause the blower motor to fail if u don't fix it u would do best to spray lube into the bairing as it may start to make noise ,good luck there are threads on all this WELCOME !!!
Welcome aboard!
I get a bath from my '10 SS after every rain - at first I was thinking that my seal on the sunroof (against wind and rain) was bad... but lately I've been thinking: shouldn't that water be draining rather than bathing?
...another thing for my to-do list!
Best of luck - post some pics!
Passenger Floor Soaked/ ...and no Moonroof 😣
Dave
Dave
Many thanks in advance!, everyone! -- Beanie
Both the antenna and the top or bottom of the windshield seal have been areas that leak .
A garden hose can help you find those leaks, it could be the door seal , is there cut away material at the side of the windshield? Like a visor was there? Maybe screw holes not sealed!
I had the same issue with my 09 ss. My driver side was soaked after every rain. The sunroof drain plug came out of the firewall and was leaking straight into the cabin. Put the drain tube back thru the firewall and sealed it. No more soaked floorboards!
