2.2 Spark Plug change?
X2.
Remove air box plastic.
Remove plug wires(don't mix them up)
Remove plugs. Spark plug socket and long extension needed
Put new plugs in with care. Don't cross thread. Torque to specs
Put plug wires back on in correct order
Put plastic back on. I recommend changing the air filter (if its old) too because you'll have it apart
When I was looking at my misfire issue a couple of weeks ago I pulled the plugs. With my 2.2, when you pull off the coil "cover", the plug wires all come off together, no way you could could mix them up, unless you really tried... It's all one piece with the coil packs.
That is because you have an 06. The 06 used the 2 coil/4 boot all in one unit. From 07 and up they switched to individual coils sitting on the boots connecting to the plugs. Still pretty simple to keep the wire harness correct since they are only etended inches out of the main wie loom.
Note this is not my rusted pic lol.
Or.. use an extension that has a socket lock on it.. Socket can't come off till you press the release button.
i am in Dallas and own a 06 2.2. if you want pm me your cell # and i will text you when i can call or you can call me
the big deal on the 2.2 is what year do you own?
let me know if i can help you.
aboard
aboard
badassbowtie
Maintenance and Upkeep
23
05-12-2013 02:01 PM
bigjacksauto
2.4L Performance Tech
02-10-2012 12:33 PM
