2.2 Spark Plug change?
Old 10-19-2012, 10:32 AM
docohm's Avatar
Ok, I'm pretty sure I saw the 'how to' on doing this spark plug change work but can't seem to locate it here on the HHR net site. Is it gone? Or did I see that somewhere else?
docohm is offline
Old 10-19-2012, 11:29 AM
solman98's Avatar
What exactly are you looking for? Spark plug change is pretty straight forward.
solman98 is offline
Old 10-19-2012, 11:44 AM
badassbowtie's Avatar
Welcome to the forum!
X2.
Remove air box plastic.
Remove plug wires(don't mix them up)
Remove plugs. Spark plug socket and long extension needed
Put new plugs in with care. Don't cross thread. Torque to specs
Put plug wires back on in correct order
Put plastic back on. I recommend changing the air filter (if its old) too because you'll have it apart
badassbowtie is offline
Old 10-19-2012, 12:42 PM
solman98's Avatar
When I was looking at my misfire issue a couple of weeks ago I pulled the plugs. With my 2.2, when you pull off the coil "cover", the plug wires all come off together, no way you could could mix them up, unless you really tried... It's all one piece with the coil packs.
solman98 is offline
Old 10-19-2012, 03:19 PM
07azhhr's Avatar
That is because you have an 06. The 06 used the 2 coil/4 boot all in one unit. From 07 and up they switched to individual coils sitting on the boots connecting to the plugs. Still pretty simple to keep the wire harness correct since they are only etended inches out of the main wie loom.
Note this is not my rusted pic lol.
07azhhr is offline
Old 04-06-2014, 02:18 PM
Chevy_dork04's Avatar
may i ask a dumb question , what size is the spark plug socket ??
Chevy_dork04 is offline
Old 04-06-2014, 05:46 PM
5/8, make sure you get a spark plug socket. Apply a bit of lube of some sort to the rubber grabber, or you'll be sorry when you can't get the socket out of the hole after installing the new plug.
Old 04-07-2014, 01:04 AM
Or.. use an extension that has a socket lock on it.. Socket can't come off till you press the release button.
sleeper is offline
Old 04-07-2014, 03:03 AM
cj krause's Avatar
i am in Dallas and own a 06 2.2. if you want pm me your cell # and i will text you when i can call or you can call me
the big deal on the 2.2 is what year do you own?
let me know if i can help you.
aboard
cj krause is offline
Old 04-07-2014, 05:24 AM
Welcome to the site!! seems all your questions have been answered here.
ksuemalee
06-22-2014 06:02 PM
badassbowtie
23
05-12-2013 02:01 PM
bigjacksauto
2.4L Performance Tech
02-10-2012 12:33 PM
James06
10
01-07-2012 03:10 PM
sumo1
06-30-2009 09:58 AM
Quick Reply: 2.2 Spark Plug change?
