5w20 in my 2006 2.4, problem?
I took my HHR in for an oil change and after I left and got to where I needed to be then looked at the paperwork. Instead of the Valvoline 5w30 I always have put in they stuck Castrol 5w20 in. What, if any, problems will this cause? Should I worry? I have a 600 mile round trip tomorrow.
Why not just call them and ask them to verify what they put in ? At the least, it could be just a paperwork error, and you could actually have the correct oil installed.
Plus, by calling, if it is the wrong oil, you can at least notify them of the problem and that you will be returning to have it corrected.
Thousand of people have never noticed the labels and use what grampa always used, whatever that was. Don't get all worked up about it, just get the right stuff next time.
Yeah, that is also used in some Ford models too. It is legitimately Castrol 5w20 that they put in, which is not what I specified.
There is no need to change it. It will not hurt anything.
Doesn't hurt to talk to the oil change place and let them know of their mistake but nothing will happen to the engine from running with this weight oil.
OP-
If you were using this car as a race car then it might be a problem. If you were towing a trailer during this 600 mile trip it could be a slight issue. But for your car during this time of year driving normal highway speeds you will be fine.
OP-
