Thermostat and temp sensor replacement
Old 07-04-2014, 03:46 PM
oldracer's Avatar
About 4 months ago the coolant temp would flat line but if I went over a bump it would come back? Some times I would have to hook up the Auto Enginuity software and clear out the codes for temp too low and all would be fine for a week or two. So finally this week it started happening more and more and I decided to do a thermostat and sensor replacement at the same time and the whole job took about an hour for both. I got the parts at my local NAPA and cost was about $44 including a jug of the correct coolant. I found a large 1/2 inch drive impact socket and used a long breaker bar that just happened to stick up and required only a couple fingers pressure to break the sensor loose and the same to put the new one in!
I was happy that the hardest item to break loose was the sensor as I am just getting over heart bypass surgery (5/20) so I can't do a lot of stress on my chest muscles just yet but after I finished I felt a million percent better than I would have a year ago!
oldracer is offline
Old 07-04-2014, 05:51 PM
Good for you oldracer. Sounds like you know when to pace yourself - and that's a good thing.
Hey, a couple questions:
- what shape was the old thermostat rubber gasket look like (if it had one)?
- did the new thermostat have a rubber gasket on the movable valve in the center?
whopper is offline
Old 07-04-2014, 06:21 PM
oldracer's Avatar
The old thermostat has a rubber seal in the center and it was deteriorated fairly bad. The new one had a smaller seal and looked to be a different material? The outer edge seals looked to be about the same material and size. I'll do a test drive this evening to let things get fully heated up but so far no leaks.
oldracer is offline
Old 07-04-2014, 07:34 PM
Looks like you caught it just in time with it deteriorating like that. Keep in mind that GM has changed to a non-rubber seal thermostat a while back according to some members reports. Thanks for getting back. have a good one. :)
whopper is offline
Old 07-04-2014, 10:53 PM
Technical Moderator
At least the OEM on my 2011 had no center rubber, only the main gasket was rubber.
I get an employee discount at NAPA I think I would have paid more! What's the secret?
donbrew is offline
NxlKing2304
05-29-2015 05:22 PM
Telepsychic
01-11-2011 05:21 PM
dinobass
11-20-2006 03:18 PM
joesblackhhr
2.4L Performance Tech
31
07-20-2006 04:28 PM
Quick Reply: Thermostat and temp sensor replacement
