Door Handles
Old 09-19-2016, 01:16 PM
Leeroy's Avatar
Door Handles
I need help replacing the passenger side rear exterior door handle. Any video?
Am I even in the right place?
Leeroy is offline
Old 09-19-2016, 02:40 PM
Welcome to the site, it's really simple, open the door look for the rubber plug that is on the door, pop out the plug, using a T30 torx screw driver , loosen the screw inside the door, do not use a power driver! Just a hand driver, there is a retainer and will hold the screw while you change the handle. Now, gently pull the outer handle and the smaller piece of the handle will come off. Now slide the handle toward the rear of the door and it'll come off.
Install is the reverse, real easy to do.
Oldblue is offline
Old 09-19-2016, 04:40 PM
Technical Moderator
here:
donbrew is offline
Old 11-30-2016, 12:45 PM
SixPak's Avatar
Inside door handle broken...
I've had the same broken door handle (plastic) problem on my 2011 driver's door. Bought a replacement handle on ebay for $18.
Here is a great video for the repair:
SixPak is offline
Old 11-30-2016, 02:53 PM
Technical Moderator
Except that the subject of this thread is the exterior door handle.
The interior door handle repair is very well covered on this site in the "how-to" section and in a few other threads.
donbrew is offline
HWD510
Mods - Interior
7
03-09-2007 07:11 AM
Flyboy6257
7
10-30-2006 05:58 PM
Harpozep
14
10-12-2006 09:47 AM
Songman
22
08-04-2006 12:05 PM
Quick Reply: Door Handles
