Good luck with the taillight bulbs.
No one tell him about the procedure on changing headlights...If he thought tail lights were hard...Tail lights are a walk in the park compared to the headlights...but I fix things for a living, so I don't find the headlights difficult....Difficult in my book would be the thermostat (because of its location on the SS)
I never had problems with the tail lights either. Upon first replacement I put on a thin film of silicone grease. I use that alot along with AntiSeize grease wherever I've been or see that it would be a good place to use it. 2006 here.
I agree, never had a problem with the tail or headlights. Yeh, the headlights can be kind of a PITA, especially when compared to other cars(like the wife's GTI. Pop the hood, remove, replace, close hood). But they really aren't THAT hard to replace, just a tad time consuming.
Changing brake light dangerous
I was trying to change turn signal light and wouldn't twist off. Had to remove assembly removing 3 bolts. My arm got stuck and thought I would have to call fire dept. 10 min later able to get arm out with grease. Better to take to shop i guess.
My left rear tail lamp on my '11 wagon was a bit stuck but hasnt been since that bulb change. Now on my '09 panel the right rear tail lamp bulb for the life of me
i couldnt get it to go back in and click in place fully. When installed proper the filament is straight up and down mine is off a little.
on my 2006, replaced both bulbs....not any problem doing it. did find that replacing with "glass based" WAGNERS(from NAPA) fit much better/easier than the "plastic based" ones from ADVANCE/AUTO ZONE. the OEM bulbs are "glass based" like the wagners...........
http://www.partsgeek.com/bwd4txr-che...ight-bulb.html
http://shop.advanceautoparts.com/p/s...mps+%26+lights
If your problem is that the housing is melted such that the new bulb won't go in............ you need to get a new housing.
