Rubys first oil change. Easy as silk
Old 09-01-2010, 08:24 PM
Kev&Chers{SS}'s Avatar
Her first change, 4028 miles. Valvoline syntech Full synthetic 5-30. Pureolator filter. It was simple. Especially the oil filter. 1 1/4 socket required and 10" extension does the trick. Reset oil life on dic. Done. Easiest change ive ever done on a car. now will follow Oil life indicator to about 5% for next.
Kev&Chers{SS} is offline
Old 09-01-2010, 08:26 PM
Greybeard999 is offline
Old 09-01-2010, 08:31 PM
More important.... Not a drop of oil spilled on the engine LOL
Old 09-01-2010, 08:34 PM
Easiest change I ever did also.... did mine about 3 weeks ago.
Old 09-01-2010, 08:52 PM
Cool. Who said newer motors are hard to do oil changes to lol
Old 09-01-2010, 11:40 PM
Cool, are you getting a full 5 qts in with out being a tad overfull ?
sleeper is offline
Old 09-02-2010, 12:05 PM
Yeah i put gallon in then took off block. After engine was started, let sit a bit then got 5 in looked about just right
Old 09-02-2010, 12:11 PM
I used a 5qt jug and got it all in without overfill...... 45 minute drain and I sopped up several oz out of the filter cavity with a clean rag that wouldn't normally have drained.
Old 09-02-2010, 01:53 PM
ditto..
sleeper is offline
desertrat
Maintenance and Upkeep
70
06-27-2018 06:51 PM
JWA
16
06-21-2014 12:16 PM
oldracer
29
08-16-2013 12:56 AM
gom0626
08-02-2010 03:20 PM
Quick Reply: Rubys first oil change. Easy as silk
