Monroe strut & coil spring assembly
looking to possibly replace the front struts. Found "monroe strut & coil spring assembly from partsgeek.com for 188.16 ( both left front and right front ). what does everyone recommend using?
Just replaced both front struts and rear shocks from Rock auto. Bought the "kit" with the unit pre assembled springs and struts for easier install. Replaced all of the sway bar links and rubber mounts also. Drives like new (after re alignment) and not even a sound on rough roads!
Very happy now, drives better than when it was new!
