Monroe strut & coil spring assembly
The replacement Moog links have a hex in the area just in front of the link so you can use a thin open-end wrench to hold it from spinning.
Steve
Well I was thinking of picking this up for the job. Do you think its overkill?
https://www.amazon.com/PORTER-CABLE-...rench+1+2+inch
I call it overkill because Electric Impact Wrench - 1/2"
How often do you plan on needing it?
The only routine use is removing wheel lug nuts. HF tools are great for casual use.
Well that is a much better price for essentially same tool and there is a Harbor Freight in my neck of the woods. My problem was that when I first attempted to remove the sway bar end link nut it WOULD NOT budge. I was guessing that the nuts on the strut would be even worse. Maybe I am looking to take the lazy way out.
The small nuts on the top of the strut tower are barely hand tight. The 2 bolts at the bottom on the steering knuckle are splined into the knuckle, so remove the nuts and drift the bolts out, they are only about 89 lb-ft (without looking).
The basic problem with the link bolts is that the ball, by design, spins.
I will have a crack at it without the impact tool. NOW reading through the forum I find there is an alternative to Monroe for the quick strut? A brand called Gabriel? Now I am torn as to what set to get!!
They look universal and don't come with the spring or top bearing plate!
https://www.amazon.com/Gabriel-G5681.../dp/B002VJGYJO
