Oil Leak?
Old 10-10-2016, 11:59 AM
Nazramoth's Avatar
Oil Leak?
I could use some help with this....
I need to identify where this Oil Leak is coming from... I can't really afford yet to pay a mechanic to take anything apart to inspect it; nor do I have the ability to do it myself...
A Lube Shop that recently did my oil change, took this following picture; you can see where a couple drops of oil are forming...
If anyone is familiar with whats shown in this picture, and has an idea of whats causing the leak... and perhaps has an idea of what most mechanics would usually charge to fix it... the info would be much appreciated!
I can post a larger, higher resolution, image if needed...
Nazramoth is offline
Old 10-10-2016, 12:06 PM
Nazramoth's Avatar
I am going to presume that based on the picture... the oil drops may be forming somewhere deeper in or further above whats seen in the picture, and then running down to where they're seen in the picture.
But I can't really tell; and I have no idea what it is that I'm looking at ... what parts are visible...
Old 10-10-2016, 01:32 PM
Oil dripping off the bottom of the starter, usually means the oil filter dripping oil when the filter was changed! Post a picture of your oil filter cap area
Oldblue is offline
Old 10-10-2016, 01:40 PM
Nazramoth's Avatar
You mean the plug thing... where the oil is drained from, when its changed?
He showed me a picture of that but didn't send me a copy of it. But it was fine, no oil coming from it... and he doubled checked it for me to make sure it was secured properly.
Old 10-10-2016, 04:06 PM
Technical Moderator
I can see that the side of the engine is filthy with oil, leading me to guess the valve cover gasket or the oil filter cap is leaking.
You don't have the ability to open the hood and look at the engine? I keep forgetting that I can't do that anymore. Get someone that can to look at it to locate the spot where it turns from dry to wet. The theory being that gravity pulls the liquid down, so there will be a dividing line which is where the liquid is coming from
donbrew is offline
Old 10-10-2016, 04:22 PM
Check the oil pressure switch which is hidden directly above the starter.
whopper is offline
Old 10-10-2016, 06:33 PM
The oil filter cap is located on the driver side of the engine just to the right of the intake manifold and down. The round black piece with the hexagon on it
Oldblue is offline
Old 10-10-2016, 06:43 PM
And the oil pressure switch will be below and back under from that cap housing.
firemangeorge is offline
Old 10-11-2016, 10:55 AM
Nazramoth's Avatar
Well, considering that I did not know what the Oil Filter Cap was.... then such would imply that I... did not know, that I could look under my hood and see it.
I presumed it was something that was UNDER the car; which crawling under and poking around is NOT something I can do... considering a bad back, and bad knees, resulted from an old car accident...
But now that I know, what it is, and where it is.... (thanks to those who posted pictures of what it looks like!) then I know what to look for and can check it later today, and I'll post a picture of there looks to be a problem with it!
Old 10-11-2016, 01:04 PM
Technical Moderator
I did say that I can't open my hood and look under it anymore, I wish that I was joking.
donbrew is offline
Hellraisehr
04-15-2019 03:48 PM
junker
11-18-2009 12:06 PM
alw
01-04-2009 04:22 PM
stranger
2.0L Performance Tech
7
12-01-2008 04:01 PM
pobryne
06-05-2008 09:47 PM
Quick Reply: Oil Leak?
