Passenger side bulb out, but high beam works
Old 03-15-2017, 03:30 PM
Jpak88's Avatar
Ayyy good news, my friend is gonna help me out tomorrow and save me the labor cost! Wooo
Jpak88 is offline
Old 03-15-2017, 03:36 PM
It's real easy!
Just in case you changed the other one in a different manner.
Oldblue is offline
Old 03-15-2017, 03:48 PM
Jpak88's Avatar
Originally Posted by Oldblue
It's real easy!
https://m.youtube.com/watch?v=hE4kMowR3i0
This is indeed the video guide I used! It was still just a pain, since it was so cold outside. It's not gonna be any more comfortable tomorrow when I get this other one done. It must be nice for headlights to blow in the summer :p
Jpak88 is offline
Old 03-15-2017, 04:05 PM
I wouldn't know mine like to burn out in December.
Oldblue is offline
Old 03-16-2017, 11:05 AM
Bob109's Avatar
Another reason to change both bulbs at the same time is you are pretty sure both will be the same,, brightness, color temp, and quality. I have seen a noticeable difference in light thrown from the bulbs from one place or brand to the next, plus you are sure you are using the same brand, but could be a difference from the same maker from lot of materials to another when assembling.
Bob109 is offline
Old 03-16-2017, 11:09 AM
Jpak88's Avatar
Yeah totally. It was wracking my brain to remember which one I got for my driver side last month but I'm like 95% sure it was the Sylvania Xtravision (I remember the purple packaging). So that's what I used today on the passenger side.
Jpak88 is offline
Old 03-16-2017, 11:11 AM
Jpak88's Avatar
On a related note, does anyone know if those orange reflectors near the turn signals are just reflectors or if they have bulbs? Because if they DO, mine are both out
Jpak88 is offline
Old 03-16-2017, 11:22 AM
aradmahogany's Avatar
They have bulbs... also easy to change
aradmahogany is offline
Old 03-16-2017, 11:23 AM
Jpak88's Avatar
I'll look into it. Better be easier to change than the headlights @_@
Jpak88 is offline
Old 03-16-2017, 11:31 AM
A bit easier yes, still need to pull the splash guard out and reach in there for it but its just a little thing. I only had to replace one so far. There are two in the front and two in the back. As a trick for changing headlights just turn your wheel OPPOSITE the side you want to change out and you should be able to pull back the splash guard enough to reach in there and twist the old one out and the new one in, all while looking at the housing from the outside to make sure you are getting it in there straight. I keep a plastic pin puller tool in my trunk so I can change easily and on the fly if needed! last time I had to it was in the parking lot of an auto zone and took about five minutes.
Quick Reply: Passenger side bulb out, but high beam works
