Radiator complete drain and refill.
Old 07-09-2014, 03:09 PM
slantram's Avatar
Okay, I drained the radiator and pulled the water pump drain- but I only got about 5 quarts out of it. What gives? The service manual says 7.9 quarts. Thanks, slantram.
slantram is offline
Old 07-09-2014, 03:30 PM
Don't know. Which one do you have ?
Cooling System
2.0L Engine 9.2 qt
2.2L Engine 7.4 qt
2.4L Engine with Automatic Transmission 8.5 qt
2.4L Engine with Manual Transmission 8.7 qt
firemangeorge is offline
Old 07-09-2014, 05:13 PM
Technical Moderator
Did you remove the t-stat first.
Plus, I think the recovery bottle accounts for about a quarter-half gallon.
donbrew is offline
Old 07-09-2014, 06:03 PM
slantram's Avatar
I have the 2.4 / auto trans. My 2007 service manual says 7.9 quarts. It says NOTHING about removing the t-stat first in my manual.
slantram is offline
Old 07-09-2014, 09:01 PM
Technical Moderator
The t-stat blocks the flow. It is a circuit, if there is a block in the circuit......
Sorry about the manual, they must be assUming.
I think the service manual (at least the 2006 MY) only covers the official coolant exchange method.
donbrew is offline
Old 07-09-2014, 11:42 PM
geg
geg's Avatar
about half of the volume of fluid in the radiator.
The second half or a little less - in the engine cooling ducts, piping, etc.
geg is offline
Old 07-10-2014, 03:45 AM
slantram's Avatar
My manual gives a "Static Fill"-drain the radiator and water pump. Don't quite understand the Tstat blockage thing. the Tstat is just a thermostatic valve between the block and the radiator, not a separate circuit.
slantram is offline
Old 07-10-2014, 06:21 AM
Technical Moderator
That's the point. NOT a separate circuit.
But, anyway don't agonize over it. Once you flush it all the old stuff will be gone, and the flushing instructions do include remove t-stat.
donbrew is offline
Old 07-10-2014, 09:25 AM
Blue_SS's Avatar
This is correct. However, when the engine is cold, this valve is closed, blocking flow of coolant from the engine back to the radiator. I think you got good advice on everything else, though. The flush will get the rest of it.
Oh, and make sure your hoses and clamps are good before re-filling. You don't want one to let go right after you've done all this...
Blue_SS is offline
Cardwiz428
12-23-2013 07:59 PM
logcar
Maintenance and Upkeep
18
10-21-2011 04:19 PM
diskullman
06-26-2011 07:24 PM
RICK167448
04-13-2011 12:19 AM
RICK167448
30
02-15-2011 11:52 AM
Quick Reply: Radiator complete drain and refill.
