Replacing control arms - Bolt stuck!
Old 03-27-2017, 08:43 AM
fonque's Avatar
I finally attempted to install my set of Powell racing parts control arms yesterday. The passenger side went in without too much issue. However the driver side rear bushing bolt was rusted to the sleeve.
i read on a couple of threads that there was some way to break it free using a pickle fork, but I couldn't put the picture together in my mind of how that would work.
Does anyone have a more detailed explanation on using a pickle fork to break the bolt free from the sleeve, or perhaps a picture?
Any help is appreciated!
fonque is offline
Old 03-27-2017, 08:50 AM
Just this, thread
https://www.chevyhhr.net/forums/brak...says-no-51562/
In post #20 Kookie had pictures posted , but they're gone now!
There is mention of the pickle fork , but that was to get the bolt out, after it was turned out of the threads.
I see in Kookies case the sawzall was used to cut the bolt and sleeve out.
Turn PB Blaster first! then a long Johnson bar!
Oldblue is offline
Old 03-27-2017, 09:27 AM
Let's see if I'm reading this correctly. The LCA came out but the rear bolt is still stuck in the sleeve of the bushing ?
If so, wouldn't it be easier to just get another rear bolt ?
firemangeorge is offline
Old 03-27-2017, 09:52 AM
Technical Moderator
Normally the bolt gets stuck in the sleeve, not the nut. I would try to loosen the nut then after liberal application of WD40 (or your choice may be PB blaster) use a pickle fork to bust the corrosion. Last resort would be a new bolt and a sawzall.
donbrew is offline
whopper
"How To" Tutorial Library
162
01-07-2021 06:10 PM
R CA HHR
37
08-06-2019 08:15 AM
oldracer
02-11-2017 03:53 AM
chaosdsm
Maintenance and Upkeep
17
01-30-2017 02:38 PM
JimmyJangle777
03-29-2016 07:45 AM
Quick Reply: Replacing control arms - Bolt stuck!
