Replacing Headlight Bulbs
Old 03-05-2015, 06:56 AM
  #51
PURENEWF's Avatar
PURENEWF is offline
Old 03-05-2015, 07:44 AM
  #52
DavidLadewig's Avatar
I've changed mine and it was pretty easy. Just be sure to turn the tire where it is out of your way. You will need new plastic pins. The old ones will fall out eventually, so I replaced mine.
DavidLadewig is offline
Old 03-05-2015, 07:48 AM
  #53
Technical Moderator
Originally Posted by PURENEWF
Where is the fuse for the headlight?
Follow the link in my Sig for an owners manual. Or type "online owners manual" into the search box.
donbrew is offline
Old 03-05-2015, 11:09 PM
  #54
hhr06NJ's Avatar
I spent more time trying to get the plastic push pins out than anything else;
next time i am going to buy a pair of plastic pins with the bulb, and the right tool too.
and yes, i drew blood, both times;
REAL IMPORTANT: make sure old rubber gasket comes off (they get stuck on the housing).
hhr06NJ is offline
Old 03-06-2015, 06:09 AM
  #55
Technical Moderator
NAPA will sell you a bag of the retainers for a few $. Probably in the back room, don't bother looking on the sales floor, best to take one in with you.
Someday I'll remember to take one in and get the part number.
donbrew is offline
Old 03-06-2015, 10:02 PM
  #56
hhr06NJ's Avatar
a "standard GM" push pin matched perfectly at Advanced Auto
hhr06NJ is offline
Old 03-26-2017, 12:10 AM
  #57
Mike 2011 hhr's Avatar
Headlight replacement
Do not listen to the old man on YouTube he's an idiot. All you gotta do it turn your tire out pop the two bottom plastic clips and the center screw hold back with one hand reach in find back of bulb twist out. The wire will pull out just far enuf to get out a fender well take out bulb then without touching glass on new bulb ( if you do make sure to wipe it off very well) pull fender well back away from car reach up inside while looking threw headlight and slowly get it in hole then press and turn till it locks. If it won't turn lightly apply some bulb lube and should go right in.
Mike 2011 hhr is offline
Old 06-17-2017, 10:57 AM
  #58
albo40's Avatar
Unhappy Headlight Blues
Has anyone run into an issue with losing auto-on feature after replacing headlight bulbs?
Just replaced mine and this has happened.
Worked fine with replacement of drivers side, but lost it once passenger side got replaced.
Has me stumped.
Hopefully will get it resolved without getting mechanic involved.
Going to be tough going back to old school on and off having driven HHRs for 10 years.
albo40 is offline
Old 06-17-2017, 11:18 AM
  #59
Technical Moderator
Auto on has nothing to do with the bulbs, only the sensor on the dashboard.
What, exactly do you mean and what year is the HHR in question?
The only thing I can think of is the new bulbs are defective, no low beam.
donbrew is offline
Old 06-19-2017, 05:55 PM
  #60
albo40's Avatar
Gave them a test this afternoon when heading home from work.
Started the car and lights did not come on.
Shut the car off and covered the sensor.
Sure enough the the lights came on when I restarted.
By the time I got home they had automatically shut off, about 10 minute drive.
10 years and 2 HHR's they've always stayed on day or night on when set on Auto.
Never thought of it before figuring it was a daytime running light safety feature.
So all is good have hi and low beams
Thanks for the response donbrew
albo40 is offline
Wifes07LT
Mods - Exterior
10
11-08-2014 10:12 PM
Frenchy42
01-27-2014 09:13 PM
hhr-mn
Maintenance and Upkeep
14
04-07-2011 03:14 PM
andoll83
11-24-2008 10:48 PM
laylowcustoms
03-02-2008 08:38 AM
Quick Reply: Replacing Headlight Bulbs
