Dome light bulbs
Old 12-23-2020, 12:07 PM
Radco's Avatar
Dome light bulbs
Going to change dome bulbs to LED'S. ! Any trick to taking the cover off with out breaking the tabs ?
Does it matter what side of the cover you start on to remove it ?
On my truck you start on the right side as it is hinged!
And with those plastic tabs I know they are east to break !
And yes I know the cover will be a pain to reinstall from what I have read. Just have not found the answer to removing cover !
Thanks
Radco is offline
Old 12-23-2020, 12:19 PM
I’ve refrained from doing this in my 2011 2LT , I don’t want to break the tabs and there are 3 lights on the ceiling, so I’m not sure how they come off.
Oldblue is offline
Old 12-23-2020, 12:21 PM
Radco's Avatar
I hear you. I tried but stopped because they were not moving ! I was looking for a bit mor light in the back Oh well Ill save a couple bucks lol
Thanks and Merry Christmas
Radco is offline
Old 12-23-2020, 12:25 PM
Technical Moderator
Just stick something in the gap a push. No magic, just 2 tabs, no hinge. The switch may fall apart.
donbrew is offline
Old 12-23-2020, 01:22 PM
These tab slots?
On either end of the light?
Oldblue is offline
Old 12-23-2020, 03:48 PM
Radco's Avatar
Don Thanks for the info I was not sure it they were hinged like my truck. Glad to know they are not
Blue Thanks for the pictures !
Radco is offline
Old 12-24-2020, 12:12 PM
Radco's Avatar
Cargo light done. But the LED's I have were a little longer for map light middle seat lights . I assumed they were all the same size but nope lol The 44 mm Festoon too long .
Radco is offline
Old 03-02-2021, 06:54 PM
My festoons look like this
my dome lights are like these
The dome lights glow a bit after the dim down
Oldblue is offline
Old 03-03-2021, 03:53 PM
Radco's Avatar
Steve I did order and install the right ones and there is a way difference in lighting now :) I also added the LED's to my truck inside ! Cheap but nice change :) I like those square lights of yours
Radco is offline
Old 03-03-2021, 04:35 PM
It’s the square ones that won’t turn off.
Oldblue is offline
Quick Reply: Dome light bulbs
