Suspension Torque Specs?
Do I have them right?
REAR
TOP: 92FT/LBS
BOT: 66FT/LBS
FRONT
Top 3 mounting nuts: 15FT/LBS
knuckle bolt: 89FT/LBS
sway bar endlink bolts: 59FT/LBS (replacing with MOOG)
***I also need the spec for the sway bar bushing mounting brackets.
Thanks!
REAR
TOP: 92FT/LBS
BOT: 66FT/LBS
FRONT
Thanks!
imagepower
12
10-30-2015 07:50 PM
