transmission fluid
Old 05-17-2013, 02:58 PM
biglou's Avatar
transmission fluid
Sucks these cars you have to take to dealer to put trans fluid
biglou is offline
Old 05-17-2013, 03:04 PM
cornwalis's Avatar
You dont. Just need a pump to get the fluid in. Or use a funnel with a hose. Threw the top can get a fluid pump from any auto parts place just need make sure the car in lvl wheb fill it and. When check the lvl
cornwalis is offline
Old 05-17-2013, 03:08 PM
Technical Moderator
To check the level you do need to jack the car up, remove a wheel, remove the level control bolt. Fill thru the vent plug top Driver side.
To drain you need to remove the pan.
Search tool will get you lots of help.
donbrew is offline
Old 05-17-2013, 10:21 PM
sleeper is offline
Old 09-20-2013, 04:30 PM
hurst2001's Avatar
Well i thinking on changing mine then i said no .I got 170,000 miles on it and never been changed ,so i was wondering should or not ,i am kind of dam if do dam if i don't ..any inputs at all ,i am sure this has been beat to death
hurst2001 is offline
Old 09-20-2013, 05:49 PM
Technical Moderator
At 170,000 I would at least change it and the filter, but then that would be 3 years for my car. Some shops will not do a flush over 100,000 miles.
donbrew is offline
carsrmilife
11-11-2015 11:48 PM
Rooster1
Maintenance and Upkeep
01-19-2014 09:03 PM
skyline26
06-27-2013 10:42 AM
wgiff
01-26-2011 02:44 PM
Lone Ranger
06-13-2007 09:48 PM
Quick Reply: transmission fluid
