Blacked out Grille and Mirror Covers
Old 01-19-2016, 06:09 AM
aradmahogany's Avatar
Originally Posted by DavidLadewig
Can you really get plasti dip off easily? I've never used it, but would like to on some wheels.
As long as you put at least 5 or 6 thick coats on when the time comes it will peel right off.
aradmahogany is offline
Old 01-19-2016, 06:54 AM
DwRed2LT's Avatar
how warm does it have to be for it to dry corectly ?
DwRed2LT is offline
Old 01-19-2016, 11:10 AM
That is not something I would know. I didn't have any difficulty with temperature as I am in Florida. I just read briefly that it is recommended to be applied outside when it is at least 60 deg F, but if you "keep the can warm" while applying then you should be good. Since it is basically liquefied rubber pressurized in a can, the product may tend to gum up and spray funky. Also, the nozzle might get clogged. But, the product has been stress tested from -30 to 200 deg F and maintains its structural integrity.
Old 01-19-2016, 11:11 AM
Plasti Dip Tech Tips | Plasti Dip International Blog
for reference
Old 01-20-2016, 11:15 AM
DwRed2LT's Avatar
Thanks aradmahogany !
too cold here right now.
DwRed2LT is offline
Old 02-10-2016, 10:57 PM
henr1e's Avatar
There's specific plastidip remover that you can buy. Using Goo Gone spray can also make your job easier.
henr1e is offline
Old 02-15-2016, 11:59 AM
Lethal Tendencies's Avatar
looks good
Lethal Tendencies is offline
Clarmor
Mods - Exterior
06-25-2011 09:35 AM
mobster wagon
05-06-2008 03:04 PM
tjplogg
03-22-2008 07:01 PM
914nickd
19
09-01-2007 06:05 PM
DARK AGE 53
20
09-20-2006 05:19 PM
Quick Reply: Blacked out Grille and Mirror Covers
