Chevy Bow Tie
I think I'll shape the plug from wood.
I Think I Got It
Ok boys and girls, after spending waaay too much time on checking out the 3D printing of a smaller 55 Chevy trunk emblem for my V8 car, I got a break thru. A '56 V8 Chevy hood emblem is much smaller because it fits above a gold "V" on the hood. It measured about 7 1\2" wide which is just about correct for the HHR proportions. Putting it on the rear lift gate trim should be pretty simple. I'll mock that up this week-end. The front is going to be much harder and more expensive. I want to stay with the SS grill so I'll need another set of the egg crate inserts to cut up. This won't be cheap as I will probably have to get them from the dealer. It will take a fair amount of surgery to get rid of the "jog" in the grill around the bow tie.
Here's what it will look like
I think this idea will actually work
So I cut and sanded the the protrusions off the lift gate trim in the bow tie area and drilled a couple of alignment holes. The parallelogram area under the bow tie needs to be shaped with a porting tool and the top area needs to be filled in. The emblem didn't show up very well so I shot it with primer just to see how it's gonna look.
