HID retrofit
That's what I thought as well.
But maybe I can tap into the fuse and pull the relay?
That way I don't have to cut any wires...
The headlight wire would control the HIDs and no longer have DRL function and then I can run a line from the fuse to my own relay and trigger the LEDs.
How about that???
What fuse is it?
I wonder if I could shove a lightbulb in the fuse location with an add a circuit adapter and test if it works.
So your saying the BCM sends a signal to the relay but it first goes through a fuse? Or fuse after the relay, which may still work?
How about that???
What fuse is it?
Ohh yeah, what about when I unlock the car and the headlights turn on?
Are those the DRL turning on until you start the car or are those the low/high beams?
And I believe I can turn that feature off in the dash options where you can reset the oil.
Low beams low power = DRL.
You could run a new wire from the fuse box to the new DRL lamps. That would take care of that . Either the headlights are on or the DRLs are on, failsafe relays. I might look at the difference in wiring between 2006 and 2007. 2006 has the turn signals for DRL.
Run a wire from the "out" side of fuse #31 (disconnect the existing wire c2) purple wire.
The BCM supplies GROUND to the relay. The relay supplies 12V to the fuse. There must be a diode somewhere to limit the voltage for DRL. Connector c121 is near the L headlight, you could probably just cut the Purple wire there and tap it.
The 2006 model has no DRL relay.
The wiring confuses me. I may be wrong.
Or since the relay powers the fuse, I can pull the fuse, tap into the positive side of it and add a new fuse leaving the old one out.
If 12v shows up at the fuse then I would get power to my new DRL but with the old fuse removed the old DRL circuit will remain open and won't interfere.
If it's not 12v, I don't see in the circuit where the voltage drops, but it does show .35 per unit, vs the low beam .5pu so there is definitely less voltage appearing.
I figured if you tapped & cut at the connector, the DRL system would just operate as designed but use your new LEDs and use less wire.
I'm taking a wild guess there is a zener diode at the c1 branch. If something is cheaper diode they would use it.
PU means purple wire. I thought the .35 was the wire size, can't figure the 359.
Oh, ok cool.
I also decided on fast bright f3 ballasts 35w. I heard they were good and reliable.
You guys heard of them?
And any reason I should go with 55w vs 35w?
I figure the 35w will stay cooler and still provide plenty of output???
