How to remove the Front Grille Bowtie Surround
Old 06-26-2013, 03:20 AM
BunglerHHr's Avatar
How to remove the Front Grille Bowtie Surround. I can get the Bowtie itself off with no problem. My question is how do you remove the chrome surround off the Grille itself.
Here's a link to illistrate what I'm trying to accomplish:
http://imageshack.us/photo/my-images/826/2u7.png/
Many thanks in advance
BunglerHHr is offline
Old 06-26-2013, 10:49 AM
Dracos's Avatar
Since you used one of my pictures (the bottom part is from this thread), I feel obligated to reply.
If I understand the question correctly, the suround, as you call it, is molded into the grille plastic. To remove it, you would need to cut it out and custom form a replacement section.
Dracos is offline
Old 06-26-2013, 04:45 PM
BunglerHHr's Avatar
Thanks Dracos for your time,
The area I want to separate is the chrome piece that surround the Bowtie. It appears to be a separate area. There are two small pins in the back. Here's a picture of another members grill that clearly shows what I would like to do.l The object is to re purpose in a similar manner as the picture shows. Here's a link:
http://imageshack.us/photo/my-images/818/9yz.png/
Thanks again
Old 06-26-2013, 04:56 PM
Dracos's Avatar
Now I'm fairly certain I don't understand what you're asking, the pictures don't match the question. That pic is a "no bar" grille, where the bars have been cut out of the grille surround. That one has gutter guard as a mesh, to which the bowtie is mounted.
The grille is actually chrome plating over plastic. In my pic that you used, the grille has been de-chromed. That process is covered in detail in the thread I linked. The plastic is gray; the yellow circle in the bowtie area is the epoxy I used as filler (which is also visible where the ends of the upper and lower bars used to be).
Dracos is offline
Old 06-26-2013, 05:58 PM
BunglerHHr's Avatar
Hey Dracos,
I apologize for the confusion. I kept on researching this and found the answer on Ebay. Here's a picture of the Emblem Assy.
http://imageshack.us/photo/my-images/607/6fz.png/
There it is as a separate piece which is mounted with 3M tape. Now I know how to proceed.
Thanks
Old 06-26-2013, 07:06 PM
Dracos's Avatar
Yes, the entire badge is held on by 3M tape. Saw through it with fishing line, and have a bottle of Goof-Off ready to clean it up.
Dracos is offline
LowHHR
12-22-2012 10:41 AM
congasfuse
10
08-11-2011 10:25 PM
erf2u
13
03-09-2007 09:00 PM
MOTRV8D
11-10-2006 12:02 PM
dan-d
Mods - Exterior
05-01-2006 10:52 AM
Quick Reply: How to remove the Front Grille Bowtie Surround
