LED fog and headlights
Old 05-21-2016, 09:59 AM
Ron Hinsdale's Avatar
Any of you guys considering changing fog light and or headlight bulbs to LEDs check out the LEDs at JDM Astar. These are very high quality units and are so easy to install. I have replaced both fog and headlight bulbs in my '08 LT. Very satisfied. Josea Cornejo at JDM Astar was very helpful in making the right choice for my HHR. The difference between OEM bulbs and the LEDs are very impressive.
1Z51vette
Ron Hinsdale is offline
Old 05-21-2016, 11:27 AM
Thread moved to Mods - Exterior as it is not exactly a Front Page News item.
whopper is offline
Old 05-21-2016, 12:31 PM
gio89kid's Avatar
Yeah, I had the led headlights for a while. They didn't last too long, the output was bad but they looked cool. And they used to reflect all over the place so they were bad for other drivers.
Right now I'm in the process of an HID retrofit.
Also, I haven't tried LEDs in the fog lights yet, but I really want to try to make a sharp cutoff line both top and bottom by blocking some of the lens to see if that works. That way there is no reflection from the ground and the beam should be able to cut through fog!
gio89kid is offline
Old 05-21-2016, 06:02 PM
So far I am well pleased with the light output and pattern it puts out. The headlight LEDs I purchased have the ability to change the light pattern after you install them. They are the 8th generation of LED bulbs. I hope you find a bulb of whatever type that works well for you.
1z51vette
Double0
47
10-28-2019 05:39 PM
skyline26
14
05-08-2015 10:21 AM
daddy2isaiah04
15
08-01-2010 12:33 AM
bigpapa_76
10
11-29-2009 05:35 PM
Quick Reply: LED fog and headlights
