Rendering rear body mods SS
Old 06-18-2016, 09:50 PM
Technical Moderator
The window could pop out then slide up on tracks.
donbrew is offline
Old 06-23-2016, 05:47 PM
TkHHR's Avatar
Rear Hatch Shaved
I did this Photoshop a few years back. Still want to do it too.
TkHHR is offline
Old 06-23-2016, 10:48 PM
ULOS2A6's Avatar
I really like the photoshop you did. Could you do the same but remove the top tail lights and leave the bottom ones? Another idea I have is to make the gas filler through the taillight.
ULOS2A6 is offline
Old 06-23-2016, 10:56 PM
ULOS2A6's Avatar
Donbrew, I am not sure what you mean by having the window pop up and slide on tracks. Do you mean the track would be inside and the window would slide up by the headliner inside the vehicle?
ULOS2A6 is offline
Old 06-24-2016, 11:01 AM
TkHHR's Avatar
I will have to look for the original file for this image. It was 2 computers ago but I may have it somewhere. I see you are in Fullerton? You may see my panel driving around sometime since I am also in Fullerton.
TkHHR is offline
Old 06-24-2016, 11:38 AM
Technical Moderator
tracks mounted on scissor joints. So the window would pull toward you then slide up the tracks. You could probably engineer it so you could open the gate while the window was up.
donbrew is offline
Old 06-24-2016, 07:48 PM
ULOS2A6's Avatar
I will keep my eyes open for your panel. I really like your 2tone paint.
ULOS2A6 is offline
Old 06-24-2016, 07:55 PM
ULOS2A6's Avatar
I am going to buy a used rear hatch and put it in my bench, remove the window and see what options I have. I will definitely try any idea that works. Who knows, maybe your idea will be the easiest!
ULOS2A6 is offline
Old 06-25-2016, 09:20 AM
Just a thought! You have a panel, so how about removing and filling the back window in!
A true panel with no rear windows, fill the license plate , do the dual exhaust and a flip down tag plate!
Oldblue is offline
Old 06-25-2016, 01:07 PM
lasater's Avatar
Honestly, I'm not getting this opening rear window. The glass is glued in so you are going to have to make some sort of weather seal. The mechanics of the hinge/locking mechanism is going formidable. Serious fab skills are going to be required. And, if you did a really perfect job, it would look stock when closed. What????
Like I said, I just don't get it. What am I missing?
lasater is offline
Quick Reply: Rendering rear body mods SS
