Heated seats
Heated seats
I`am new to the HHR forms. I have a 2011 1LT / LT. It does not have heated seats. Is The Lt already wired for heated seats. If So can I just get heated seats and the dash control from a pick & pull salvage yard. Is the harness under each seat. What else would I need . The pick & pull wants $35.00 each and I think about $20.00 for the controller. Thanks Lynn
You would have to double check for the harness ,the pick a part should be able to supply the harness if you need them.
As you've asked the same question in the other thread
https://www.chevyhhr.net/forums/gene...p-21280/page3/
I'll delete that
I'll delete that
Moderator Lucky did it, I spent 5 minutes going through the first page of search results, that's all I can spend on it. Most questions are answered in the other thread you posted in.
IIRC; you have to run a few wires and have some knowledge.
Sence you have an lt the wiring my be there. I installed heated seats in my LS. The wiring was not there so I had to run them.
You should be able to look under your seats and see if the connectors is there.
Do you have a power drives seat?
