Mods - Interior Discussion related to the looks of the interior of the HHR.
Upgrading rear view mirror
Old 04-12-2015, 02:35 PM
Lucky's Avatar
Originally Posted by pdmorris1
Was the rear view mirror with auto dim and compass standard equipment on the 2011 HHR LT -1 or was it part of an option package?
I'm not sure. I think it was standard on the higher LT models.
Lucky is offline
Old 04-12-2015, 07:13 PM
pdmorris1's Avatar
Does anyone no the gm part number for the mirror used on the HHR with auto dim on star and compass? I think it was maybe a gentex mirror. The mirror I got on eBay has the temp also which I don't think the HHR ever had in the mirror.
pdmorris1 is offline
Old 04-12-2015, 08:25 PM
Lethal Tendencies's Avatar
A gentex gntx-511 has compass ,dimming, on star
Lethal Tendencies is offline
Old 04-12-2015, 08:37 PM
Lucky's Avatar
Here is a thread that shows connector pin out that may be helpful.
https://www.chevyhhr.net/forums/gene...-anyone-20322/
Lucky is offline
Old 04-13-2015, 06:10 AM
Thanks Lucky!! Just to confirm this will make the auto dim , compass and map lights functional?
Oldblue is offline
Old 04-13-2015, 07:39 AM
Lucky's Avatar
Yes it will. Your just adding one battery key on power wire the rest is already there. If you have a sun roof the switch is a great place to find the key on power.
I don't have a sun roof so I had to go to the fuse box to find one.
The map/dome lights will work Just as they always have.
I did not hook up the reverse wire. I have used this for a year and a half now and have not seen any difference between this one and my 08 that came from the factory.
I think I enjoy the compass more than the auto dimming part of it but it work well.
Lucky is offline
Old 04-13-2015, 07:41 AM
So I am correct in my count of just 4 wires to get this baby working??? Thanks for the link
Oldblue is offline
Old 04-13-2015, 07:50 AM
Lucky's Avatar
You are correct.
If you have any problems with it just give me a yell and we will get it figured out.
If you enjoy that mod I can walk you through heated seats upgrade. It's not as hard as it looks.
Lucky is offline
Old 04-13-2015, 08:31 AM
I'm always in the hot seat it seems, so I'll skip that mod!
Now where in the fuse panel did you tap ignition switched 12v?
Oldblue is offline
Old 04-13-2015, 01:12 PM
pdmorris1's Avatar
The mirror I got on eBay the 511 has the auto dim, the on star, temp and compass. I already have the map lights in the roof above the dash storage, i understand that the temp and compass read out in the same window. Do I need to run a separate wire for the temp to somehow splice into my temp sensor where ever that is? I get my temp now in my instrument cluster
I paid 35.00 for this mirror on ebay
Quick Reply: Upgrading rear view mirror
