Heater Blower/Fan
My heater will not blow air anymore. I have checked all the fuses and they appear to be okay. When i turn the fan switch, nothing happens. It worked one day and the next it didn't. What should i look for now?
test the blower fan itself use a volt meter and see if it is getting power
Also check the blower resistor. Ours would only work on the high setting after getting wet from the infamous cowl leak. They solved the problem by replacing the resistor.
mine also crapped out after the infamous cowl leak, they replaced the blower fan under warranty, been good now for 150,000 miles
© 2024 MH Sub I, LLC dba Internet Brands
