TC Light Issue
Old 05-24-2012, 08:06 AM
Lee3333's Avatar
TC Light Issue
Are the ABS and traction control linked together in the HHR? I know they are in my wife's 1999 Saturn. If so, perhaps there could be some correlation with the ABS and the infamous T/C problem that I and many others have. And like I said in other posts, it has NOTHING to do with changing the intake, like the dealers try to claim. I know because after I had my problem, I went back to the old setup and it did not help. In addition, I know several other HHR owners that never touched their intake, or did any modifications at all, and they are also plagued by having the T/C light come on, the code thrown, and the rough shifts until they restart their car.
Lee3333 is offline
Old 05-24-2012, 08:29 AM
ChevyMgr's Avatar
Bad TCM will cause this.
ChevyMgr is offline
Old 05-24-2012, 04:04 PM
Lee3333's Avatar
Never thought of that. Where is it located, and how can I check it? My problem began 5 years ago, and has gotten progressively worse. In the beginning, it would only throw a code when if I did a burn out, or the tires lost traction in wet weather. As time went on, it would happen if I stepped on the gas too hard. Finally, it began coming on by itself, sometimes while I was coasting or stopped at a traffic light. Very annoying, and the dealer was no help saying he couldn't check it since my vehicle was modified (different air cleaner).
I never heard this possibility before and want to investigate it! Thanks.
Lee3333 is offline
Old 05-24-2012, 05:52 PM
ChevyMgr's Avatar
Moved these posts from the brake job thread.
ChevyMgr is offline
Old 05-24-2012, 05:57 PM
ChevyMgr's Avatar
TCM is number 2 in the picture. Requires programming after replacing.
ChevyMgr is offline
Old 05-24-2012, 06:11 PM
Lee3333's Avatar
Thanks for relocating this-it was getting a little hijacked.
Now, could you please tell me other symptoms of a bad TCM. I imagine replacing it is costly and so I want to be sure it will solve the problem.
And again, thanks for this new information.
Lee3333 is offline
Old 05-24-2012, 06:27 PM
ChevyMgr's Avatar
Cluster going dead or flashing, speedo stopping or bouncing on it's own, hard shifting, TC or ESC lights, Check engine lights, reduced engine power. All are usually intermittent. A scanner will pick up the data loss from the TCM when the problems occur.
ChevyMgr is offline
Old 05-24-2012, 07:18 PM
Lee3333's Avatar
Funny you should say that. Last year I had a problem with the heater control panel. The lights would sometimes flash like crazy. I replaced it, and it was ok for a while but now they are beginning to flash intermittently again.
And thanks again for your quick responses. You are the wizard!
Lee3333 is offline
Old 05-24-2012, 07:42 PM
the_shmoo's Avatar
Had this problem on my daughters 07 Cobalt, traction control and ABS light. Turned out to be front wheel hub bearing.
Also common on our HHR's. Hope this helps.
the_shmoo is offline
Old 05-24-2012, 08:28 PM
Lee3333's Avatar
Thanks for the suggestion. Supposedly, my dealer checked all the hubs but when I get a chance I am going to bring my car to a good friend that owns the race shop that did the fabrication and prep work on my race Jeep. He is a master diagnostician, and hopefully can figure it out (along with the problem of the engine shutting off when I hit a big bump).
Lee3333 is offline
Rockerbilly
07-29-2015 01:01 PM
Mak22492
Drivetrain (Excluding Engine)
01-20-2015 11:09 AM
racer-ray
11-29-2010 06:38 PM
BlackknighT
08-14-2010 11:58 AM
indy8six
08-11-2009 09:11 AM
Quick Reply: TC Light Issue
