*Service Airbag* light keeps coming on
Old 04-08-2014, 08:21 PM
  #41
Snoopy's Avatar
Nobody can really tell you which connector. It is a matter of trial an error. After all, we are diagnosing through electrons.
Have you read this entire thread. It provides some examples. You might also use the Search tab, top middle, and locate other SUGGESTIONS.
Snoopy is offline
Old 04-09-2014, 09:17 AM
  #42
Technical Moderator
It should be noted that the BEST and ONLY advice concerning airbag system repair is "let a professional do it". They can be dangerous if you don't know what you are doing. It is definitely dangerous to drive when they are not working.
Any amateur touching of the system is at your own risk.
donbrew is offline
Old 10-19-2015, 06:33 AM
  #43
JackALope3's Avatar
I've been monitoring this thread for a while because the symptoms also appeared in my 2009 HHR. It seemed the service airbag warning came on randomly. Having read the thread, I now suspect it was due to plugging in my iPhone power supply. I swapped batteries yesterday and discontinued using the power supply for my iPhone. So far the results are no Service Airbag warning.
I appreciate MindDrive starting this thread. Its helped me a great deal. But I don't think i'd ever want to do business with him.
I've found GM cars to be quite reliable and well engineered. I think they are a good value. And no, I don't work for GM.
JackALope3 is offline
mysistersdiary
08-23-2013 04:43 PM
catfish1954
08-05-2013 08:58 PM
befisher77
08-15-2012 08:51 PM
jdzialak
08-21-2010 08:22 AM
JTCorbin
05-06-2010 08:04 PM
Quick Reply: *Service Airbag* light keeps coming on
