06 HHR Wheel Hub Replacement Torque
Old 11-14-2010, 12:56 PM
ucadam's Avatar
I have a 2006 HHR LT 2.4 Im getting ready to replace the left front wheel hub... What is the torgue on the hub...? Should I torgue any of the other bolts..if so to what..?
ucadam is offline
Old 11-15-2010, 12:29 AM
HHR Axle nut 81 ft lbs, & Hub bearing bolts are 85 ft lbs.
edit: Lug nuts 100 ft lbs in increments.
sleeper is offline
Old 10-24-2013, 01:51 PM
West09LT's Avatar
Does anyone have a chart on what the torque specs should be on the caliper bracket bolts or any of the other bolts that should be torqued down on an hhr?
West09LT is offline
Old 10-24-2013, 02:24 PM
Technical Moderator
Keep an eye on your PM. I'll send you a link when I get to it.
donbrew is offline
Old 10-24-2013, 02:30 PM
courtesy of a copy/paste from chevymgr's post (easily found via the SEARCH tool at the top of the page - looked for Brake caliper Torque):
•Brake Caliper Bleeder Valve - Front (J41, JL9, JM4)-----11 N•m-- 97 lb in
•Brake Caliper Bleeder Valve - Rear (JL9)------------------11 N•m-- 97 lb in
•Brake Caliper Bracket Bolt - Front (J41, JM4)-------------115 N•m-- 85 lb ft
•Brake Caliper Bracket Bolt - Front (JL9)-------------------130 N•m-- 96 lb ft
•Brake Caliper Bracket Bolt - Rear (JL9)--------------------115 N•m-- 85 lb ft
•Brake Caliper Guide Pin Bolt - Front (J41, JL9, JM4)-----35 N•m-- 26 lb ft
•Brake Caliper Guide Pin Bolt - Rear (JL9)------------------35 N•m-- 26 lb ft
•Brake Hose Fitting Bolt - Front and Rear------------------40 N•m-- 30 lb ft
Look on your RPO list in the glove box to determine which spec to use.
whopper is offline
metalhead52
04-18-2015 07:53 PM
HWD510
08-25-2012 10:55 PM
Lethal Tendencies
Tires & Wheels
01-08-2010 08:03 AM
millerrdjr
05-10-2008 08:50 AM
Krusty
04-07-2008 02:39 PM
Quick Reply: 06 HHR Wheel Hub Replacement Torque
