2006 HHR Outside Mirror Switch Up Doesn't Work
Old 03-05-2010, 09:53 AM
Sparky21440's Avatar
Hi Guys,
New to this forum. Have a question about my 2006 LS. The outside mirror switch doesn't work to move the mirror up, down works fine. This morning the move right switch stopped working but left still works. This is only a problem when the wife or kids drive the car because they move the mirrors and all I can see is the ground, then I have to roll the window down and push on the mirror glass so I can see something useful.
Has anyone else had this problem, did a new mirror switch fix the problem, can the switch be replace just by pulling the door pull cup out, is there a cheaper place than GM Part Direct to get the switch ($45 seams a little excessive for a stupid mirror switch)?
Any input you guys have would be appreciated.
Thanks in advance.
Sparky
Sparky21440 is offline
Old 03-08-2010, 12:26 PM
labtec6's Avatar
I had a similar problem. Eventually, it stopped working altogether. I was checking fuses and found that the fuse was burnt. I replaced it. When I went to try the switches, it didn't work, but I got the "blue smoke of doom!" and the fuse went again. Changing the switch should resolve the issue.
labtec6 is offline
Old 03-08-2010, 03:01 PM
debsmojo's Avatar
I just had this issue with my 06 LT2. The dealer fixed it under warranty. The explanation I got from the dealer was that it had something to do with the power rearview mirror - not sure why that would affect it, but it's now fixed!
debsmojo is offline
Old 03-09-2010, 04:54 PM
Hey debsmojo,
Is you LT2 still covered by the general warranty (3/36), or is it a "Program"? My LS has 50K and was born about 4 years ago.
Thanks,
Sparky
Old 03-09-2010, 10:32 PM
debsmojo's Avatar
I just bought it certified used, with an additional 12/24000 bumper to bumper....
debsmojo is offline
Old 03-10-2010, 08:46 AM
Debsmojo,
Thanks for the answer. Guess I'll order a mirror switch from GMPartDirect.com.
15261340 $28.64 + Shipping.
Sparky
phbassnotbass
09-28-2021 08:59 PM
Jeffharden1
08-25-2014 01:50 PM
tim75901
02-26-2014 08:59 PM
woodman17
11-21-2013 10:35 AM
JamesCardoza
08-15-2013 07:01 PM
Quick Reply: 2006 HHR Outside Mirror Switch Up Doesn't Work
