CEL with P1174
Old 01-10-2011, 07:48 AM
Former Sponsor
Tony_SS's Avatar
Exclamation CEL with P1174
I got the code yesterday and now the gas mileage is pretty bad. I called the dealer and they said it might not be under warranty. What BS! Car has 56k, how can that not be under the powertrain warranty?
$%@Q%Q@@!
Anyone else have this issue?
Tony_SS is offline
Old 01-10-2011, 07:51 AM
Used the search function with the code and some other members have had the problem. Check this out:
https://www.chevyhhr.net/forums/show...0&postcount=60
HillsdaleHHR is offline
Old 01-10-2011, 08:36 AM
Zagohhr's Avatar
I had it. It seems that is fuel lean mixture. I rid this code changing the #2 & #3 fuel injectors... if you want to throw away your money (as I did), use tons of fuel additives.
Zagohhr is offline
Old 01-10-2011, 08:54 AM
Former Sponsor
Tony_SS's Avatar
Well, I did just replace a dirty air filter, then filled up on gas. I got the light about 60 miles later.
Just this morning the light went off.
Funny thing is, our remote start did not work, now that the light went off, the remote start works again. Oh well, fingers crossed!
Tony_SS is offline
Old 01-10-2011, 12:09 PM
skyeglen's Avatar
As long as there is a CEL showing, the remote start will not work. Until the code is cleared the ECM will not allow remote start.
That is only one of many reasons that the remote start will not work.
skyeglen is offline
Old 01-10-2011, 12:18 PM
Former Sponsor
Tony_SS's Avatar
The remote start works now. It worked as soon as the CEL light went off.
Tony_SS is offline
jschmieding
01-02-2019 08:20 PM
jdevries
01-02-2015 12:09 PM
justinrsetzer
05-01-2012 02:44 PM
sunbound
08-29-2008 11:07 AM
Quick Reply: CEL with P1174
