Engine swap?
Old 03-20-2017, 06:12 PM
jlhjr68's Avatar
Engine swap?
Hi,
I have a 2007 hhr and I want to put a 2009 motor in it. what do i need? any help is appreciated .thanks
jlhjr68 is offline
Old 03-20-2017, 06:59 PM
Welcome to the site, a few questions
What engine does your 2007 have, 2.2 or 2.4?
What engine is the 2009?
You seethe 2007 2.2 litre is not compatible with a 2009 2.2 or 2.4 because of the VVT
Oldblue is online now
Old 03-20-2017, 08:10 PM
jlhjr68's Avatar
The 2007 has the 2.2, The 2009 also has the 2.2.
why cant you use the 2.2 VVt? isnt it the same motor?
jlhjr68 is offline
Old 03-20-2017, 08:13 PM
Different motor, different wiring harness
RJ_RS_SS_350 is offline
Old 03-21-2017, 06:19 AM
jlhjr68's Avatar
can i just get the motor wiring harness with it and the ECM, would that work? I have a chance to buy this motor, and dont want to pass iit up
jlhjr68 is offline
Old 03-21-2017, 07:31 AM
Been discussed before on this forum. If I recall correctly, it's not just an engine, ecm and wiring harness involved.
The problem is not just that it's a non VVT--- VVT engine swap, but the fact that you are trying to swap a flex fuel engine into a non flex fuel car.
Don't remember the details but maybe someone can find that old thread that explains it.
firemangeorge is offline
Old 03-21-2017, 08:35 AM
As Avril sings! It's Complicated
But there's nothing you can do that can't be done!
If you get the complete 2009 HHR, let's say it's collision damaged, you'll have everything you need for the swap!
Old 03-21-2017, 08:36 AM
Technical Moderator
Need a BCM too.
Do you own a Tech2 and have a subscription to TisWeb?
Just a lot cheaper and less problems to get a 2007-2008 motor.
donbrew is offline
Horazz
02-06-2023 12:24 PM
DBHHRLT
2.4L Performance Tech
10-20-2014 05:41 AM
RF2
01-12-2014 08:36 PM
skuzzlebutt
11-03-2013 09:58 AM
xzombie
09-01-2009 02:18 PM
Quick Reply: Engine swap?
