ABS and anti skid warning lights
Explaining or elaborating on the problem that you are encountering will really help.
Otherwise we get into the game of 20 questions and that doesn't usually help much in the end.
So give us some details on the problem(s) and we'll see what we can help with.
I think cuba1852 expects the title of his post to be read as part of the post.
The answer is YES, almost everybody, it seems, has had the problem. Usually it is related to camshaft position solenoids (VVT valves) getting close to death.
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Or, a bad wheel speed sensor or 2.
The more expensive code readers can read the ABS system codes. As always get the numbers not the description.
Check the wiring connections for corrosion or damage, Replace both front hubs not just one!
https://www.engine-codes.com/c0040_chevrolet.html
One source , I believe modifications are required
http://m.ebay.com/itm/131534313472?_mwBanner=1
Same kit different site and powder coating
http://m.ebay.com/itm/291765269456?_mwBanner=1
ZZP to
http://zzperformance.com/ecotec/lnf-...oler-pipe.html
ZZP to
MJC3131
12
04-11-2016 11:10 AM
helhedded
03-22-2012 06:55 AM
