Key stuck in ignition- which issue do I have?
Old 06-09-2012, 03:45 PM
denny's Avatar
Put my 2006 HHR 2.4 with automatic transmission in park yesterday and shut it off... Key turned off far enough to kill engine but radio would still work ect. I popped the cap off the steering wheel column and pushed the plunger over so I could get the key out of the ignition. Per dealer my vin number is not part of any recall ect. How do you know if the ignition switch is the problem or if the shift interlock is the issue ? Is there a simple way to determine which issue is at fault with out paying someone to start throwing parts at it? Thanks
denny is offline
Old 06-09-2012, 04:01 PM
ChevyMgr's Avatar
99% of the time it's the shifter. When it sticks, try wiggling the shifter handle and make sure the button is popping out when you put it in park.
ChevyMgr is offline
Old 06-09-2012, 04:03 PM
oneton's Avatar
Did the key come out when you pushed down the pin ? If yes it's not the lock cyl. The pin in the shifter is not hitting the mico switch to pule back pin in steering wheel. was the search there is some how to DIY
oneton is offline
Old 06-11-2012, 02:40 PM
How are things going with your HHR?
If you would like to send me a private message with your VIN, I would like to look into the special coverage information. I can't promise anything, but I would like the chance to research this for you.
ChevroletCustomerService is offline
Old 06-12-2012, 02:28 PM
hurst2001's Avatar
I have a 2007 with the same problem if your short on cash all i did was put a rubber band around the plunger part were the button is held in turn back the key and its out and everything works fine
hurst2001 is offline
dande54
08-11-2023 09:52 PM
birdswitharms
01-02-2018 05:54 PM
gfsloan77
08-27-2013 08:51 PM
dhansen871
08-22-2010 01:02 PM
jethro
01-13-2009 09:34 PM
Quick Reply: Key stuck in ignition- which issue do I have?
