best 02
best 02
I looked thru the previous posts regarding o2 sensors but couldn't find an answer to my problem.
Had the cat replaced a little while back (90,000) along with one Bosch 02 sensor. engine lite came back on after a while, turns out there was a loose part of the exhaust system at the engine, some welds broke but mechanic welded it back. that seemed to fix it, engine lite went out.
After a couple of weeks, the check engine lite came back on. Mechanic called around to some fellow mechanics and was told that a Bosch sensor can trigger the fuel code even though everything is working right.
so he's going to order one from GM.
anyone ever heard of this?
I have not seen this much on our cars but I have seen Bosch senors have problems on Chrysler systems. Chrysler even put out a tsb about Bosch 02 sensors setting false codes.
I think your tech is heading in the right direction
The Bosch sensors have a bad reputation. GM uses NGK/NTK mostly.
I used 1 in the #2 position and it was "low bias" error, meaning it just did not work. Depends on the code number. I don't know what "the fuel code" might mean.
Which sensor was replaced?
thanks much, it's good to know that my mechanic could be on the right track. Being computer challenged, I don't know which o2 it is and not sure what fuel code means either, I just know that the check engine light is on.
