No coolant temp reading and the thermostat was changed
Old 10-20-2017, 04:27 PM
mrmarkuSS's Avatar
About a month ago,I noticed the coolant temp gauge was down to zero. It did come back on the next time I started the car.
After reading up in this forum,I changed the thermostat. Problem solved. Until today,3 weeks later...the check engine light comes on...
and the gauge is zero,AGAIN...Drove it around all day,and stayed at zero.
So,is it a bad thermostat (which was brand new btw) or the sensor?
mrmarkuSS is offline
Old 10-20-2017, 04:31 PM
Did you use the ACDelco 131-158 GM P/N 12622410 ?
RJ_RS_SS_350 is offline
Old 10-20-2017, 05:22 PM
X2, anything but and this happens!
Oldblue is offline
Old 10-20-2017, 05:31 PM
X3 plus what code number did it show this time ?
firemangeorge is offline
Old 10-20-2017, 06:05 PM
mrmarkuSS's Avatar
No,one from Pep Boys.
Old 10-20-2017, 06:06 PM
mrmarkuSS's Avatar
So that means ANY aftermarket t-stat except ACDelco won't work?
Kinda pisses me off...
Old 10-20-2017, 06:07 PM
mrmarkuSS's Avatar
Let me add when I took the old one off,the old gasket was fine,not deteriorated. I used the new one anyway.
Old 10-20-2017, 06:33 PM
Hmmm. The other 2 helpers got replies. I ask about the all important code number and get no response.
Hope you figure it out. I'm done.
Old 10-20-2017, 06:51 PM
It’s been mentioned many times here, the aftermarket t-stats do not open in the time frame the computer is calibrated for , the the code gets thrown. Most likely P0128.
And only use Dexcool 50/50 mix, these Ecotec engines were engineered for it.
Oldblue is offline
Old 10-20-2017, 07:03 PM
mrmarkuSS's Avatar
The paperwork from Autozone with the code is out in the car,which is NOT home right now,so I couldn't reply.
Jeez,NO patience.
Quick Reply: No coolant temp reading and the thermostat was changed
