Butyl Patch
Butyl Patch
I need a new Butyl Patch on the Cowl it's the one that a lot of people are regluing. Mine is trashed and leaking real bad. the Chevy parts web shows a part they call a Water Deflector it is part #7 in this diagram. https://www.chevyhhr.net/gallery/fil.../8/ch06290.gif Is this the part I am looking for. Here is the GM parts web page. http://www.gmpartsdepartment.com/par...agramCallOut=7
Looks like you found the right part. I found the same diagram in another posting here and they referred to the patch as the Water Deflector, as well.
If it helps, I needed a new one a while back, and just picked it up from a local dealer - it wan't much more expensive than ordering it online, and I got it the same day.
Good luck with the repair.
very frustrated with leak
I have a 2006 hhr with a sunroof and have cleaned out the windshield drains and resealed the part that everybody seems to be replacing with aluminum flashing. Ended up with 2 inches of water on the passenger floorboard again today and am going to try to find the sunroof drains to see if that is it. This is getting really frustrating!
Happy13178
09-10-2010 11:58 PM
