Cabin blower fan doesn't always work
Old 11-20-2013, 09:25 AM
woodman17's Avatar
The cabin blower fan for my AC/Heat does not always work. Sometimes it comes on,and at other times, it doesn't come on automatically, but will later kick on. Any suggestions on what the problem/solutions might be??
woodman17 is offline
Old 11-20-2013, 09:43 AM
worn contacts in the fan speed switch, loose wiring or connections , fan motor burning out, well I could keep stabbing in the dark but check the aforementioned and see what is the culprit.
Oldblue is offline
Old 11-20-2013, 02:27 PM
X2 what Oldblue says.
Another thing. If it will work on "high" without cutting off, but is intermittent in the other speeds, then it most likely is the fan resistor module.
firemangeorge is offline
Old 11-21-2013, 10:35 AM
yes sir, firemangeorge has a great point, let us know the results of your investigation!!
Oldblue is offline
phbassnotbass
09-28-2021 08:59 PM
Jeffharden1
08-25-2014 01:50 PM
tim75901
02-26-2014 08:59 PM
purple haze
04-11-2010 09:06 PM
Quick Reply: Cabin blower fan doesn't always work
