Failures after Jump Start
Old 07-08-2009, 08:55 PM
c2vette's Avatar
While on a trip, I accidentally left the lights on overnight and ran the battery completely flat. Got a jump start from AutoClub, and followed instructions in manual closely for jump, also disconnected aftermarket accessories and subwoofer capacitor. Now my tire pressure readout is blank, and the remote (key fob actuated) lock does not work. I reloaded the original programming from my HPTuners, with no change. Going to the dealer in a couple of weeks, but wondering if anything similar happened to anyone else?
c2vette is offline
Old 07-09-2009, 05:47 AM
ChevyMgr's Avatar
It happens sometimes. Usually a BCM reprogram fixes.
ChevyMgr is offline
Old 07-18-2009, 12:54 PM
c2vette's Avatar
Dealer fixed the problem, but it took more than an hour (no cost to me). It was actually pretty complicated to finally get the BCM to recognize the keyfob and tire TPM's. Manual says to jump start from the underhood terminals, but the dealer has had 3 HHR's that had this problem after jump-start, and recommends jumping at the battery instead (that is if you can get the deck lid up with that not-easy-to-use manual release). If you have never tried this release, I suggest you do it now, see https://www.chevyhhr.net/forums/show...manual+release
c2vette is offline
cshaberts
10-11-2020 05:17 PM
Timewalker
01-10-2015 11:04 AM
F-16C
Maintenance and Upkeep
13
06-24-2013 12:48 PM
rob-cyn
02-06-2008 07:00 PM
bigbear2k
09-15-2006 07:34 AM
Quick Reply: Failures after Jump Start
