ABS & Trac control light on...but not always
Old 12-29-2008, 11:32 AM
JuMPy's Avatar
My ABS and Trac control light are on....but not always. Sometimes they shut off and both functions work when lights are off. When lights are on, both the ABS and trac control are non-functional (as you would expect). Problem seems to go away on dry days, but comes back on damp days....I'm thinking connection...dunno thou
Anyone else get this? Any ideas why the problem would be intermitent? Why would they be connected?
Any help is appreciated
Vehicle is an 06 HHR LT.
JuMPy is offline
Old 12-29-2008, 12:30 PM
Marzipan's Avatar
ESC & TRACTION Warnings May mean Low Battery
ChevyMgr rsponded to me that when ESC and TRACTION warnings appear on the DIC it is a sign of low battery voltage. It was with me. Heavy electrical load - heated seats, rear window defogger, headlights, heater fan - and short slow speed trips. Charged up the battery and warnings disappeared.
However, I continue to have a prblem with battery draining under short winter trips. Have now run an extension cord from the front bumper (where the block heater plug is) to the trunk (where the battery is). Installed a battery blanket and will permanently connect an automatic trickle charger when I find one. That way I can make my short trips and plug in my vehicle for a couple of hours to restore the battery a bit.
Marzipan is offline
Old 12-29-2008, 03:38 PM
Lee3333's Avatar
This has been a fairly common problem for some of us when we changed the intake/air filter. Is yours stock?
Lee3333 is offline
Old 12-29-2008, 04:08 PM
ChevyMgr's Avatar
First step is for a tech to see what codes are set in the EBCM. Could be numerous things on yours and wiring or a connector problem is possible.
ChevyMgr is offline
Old 12-29-2008, 04:23 PM
JuMPy's Avatar
still stock.........
JuMPy is offline
Old 02-27-2009, 12:53 PM
JuMPy's Avatar
well....been a while, just thought I would update. Shortly after the lights stayed on all the time. Turns out it was the ABS sensor/bearing hub assembly (front right). For what its worth, the codes indicated it was the module itself, but the module was fine.
All's well that ends well....sensor was changed, and problem fixed
Just thought I would update just in case someone else runs along this issue.
JuMPy is offline
Old 04-15-2011, 11:14 AM
stanley1095's Avatar
where to buy rear abs speed sensor.chevy hhr 2006 LT.
stanley1095 is offline
Old 04-15-2011, 11:34 AM
asanti's Avatar
Dealership, any autoparts store (Autozone, NAPA, Pep Boys, etc)
asanti is offline
purple people eater
09-17-2016 01:07 PM
tmjackson
04-23-2014 08:27 PM
bobnj
06-13-2013 05:17 PM
happydaze
10-08-2012 07:15 PM
brdiver
03-02-2012 09:57 AM
Quick Reply: ABS & Trac control light on...but not always
