Chirping/Squealing noise when A/C is on
I am not sure if this is anything to be concerned about but it was not happening before but it seems recently when I have the A/C on and I first hit the gas from being at a stop or really low speed my car lets out a little chirp or squeal. Not sure if is a belt or if it means there may be a air leak or something. The noise does not happen if the A/C is off.
I am just curious if anyone knows what could cause that and if it is an issue I should be concerned about. My 2008 HHR SS is still under and extended warranty so whatever it is should be covered.
Sounds like the belt slipping. If it only happens with the AC on, then I would look at replacing the belt.
Fwiw. Wear and tear items like brakes,tires,wiper blades, belts etc. are usually NOT covered by any warranty.
Yeah I thought the belt too. I am having my brakes done in the near future by my mechanic (AKA my Step Father) so I will have him check that. It didn't sound like a typical belt squeal though so I thought maybe it could be something else. I guess with the excessive heat we have had something was bound to wear out or break.
