codes on 2006 hhr with psteering error code
Heard from mechanic at 5:30.
He teplaced a fuse fir the dasboard and was able to pull three codes.
P0013
P0014
Are these the same as for the later models in the above sticky?
I.E. cmp sensor/cmp performance?
Also
pulled
U0101. He says this is failure to communicate with transmission control module.
Thoughts?
I did ask him to start with the battery both on Friday and in a follow up call this morning. He did not do so. I told him this evening that ya'll
Said that it ewally could be part of the problem. He did not seem convinced.
Shall I go in the morning and put one in?
The codes soun bad. Can you tell me more?
Thank yiu
HollyM
P0013
P0014
Also
pulled
Thoughts?
Thank yiu
HollyM
you can get on line cheaper but you have to wait on shipping
http://www.autopartswarehouse.com/se...t=Transmission Control Module
http://www.ebay.com/itm/2006-2009-CH...-/150826424210
http://www.ebay.com/itm/06-07-08-09-...65440069050368
I'll bet that if you go to your local Salvage Yard, you can get it in hand for around that $55 Ebay bid. Seems to be an incredibly popular GM item, just about every GM model with a 4 or 6 built in the 21st century.
the P0013 & P0014 codes are covered under this posting - https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
the symptoms are CEL on - codes P0010/11/13/14 - hard shifting of the tranny.
For the latest scoop, skip to the end and backtrack a few pages for the latest part numbers: ie:
https://www.chevyhhr.net/forums/show...=28779&page=14 (see recap about half way down the page)
Note: the error codes refer to the Camshaft Position Actuator Solenoids (not to be confused with "sensors").
