Coolant temp problem
It is an ACDelco 180 OEM
Well, the one you have is stuck open or the temp sensor is defective. I can't think of any other reason it would run too cold. Maybe an air bubble fooling the sensor.
Topping out at 160F is pretty low, mine would run 172F when it was stuck.
First post but been lurking around...
Same issue as original poster....first time, replaced tstat with a Napa tstat. Ran anywhere from 168-171 degrees. That worked for about a week until the ---f came back. Then today, I replaced my tstat with acdelco and my temp gauge/ ac is working again. It is now running anywhere from 183-189 degrees. My concern is that my CEL never came on at all, ever. Is that something else I should be concerned about or maybe it's just one of those electrical gremlins? Thx.
A. Above 180F is "normal"
B. Below 180F is BAD
C. Assuming the code you got was P0128, the problem is the coolant did not warm up to 180F fast enough. The CEL does not always come on.
D. The t-stats job is to get the temp UP, not down.
Ok I'm back again....
So I put a GM thermostat in the car...it ran good, no issues everything working fine for a couple weeks. Temps were fluctuating between 195-204 normally driving so I thought it was fixed.
Yesterday I get the "---" again. And no a/c.
Temp sensor? Ecu? Any suggestions thx.
