Dead battery
Dead battery
Left lights on, power saver did not shut off the power drain. Battery was dead in 3.5 hours. Got a jump start from a portable battery box. Car started, very rough idle, and strong fuel smell. Two messages in dash display. One said something like reduced engine performance. The other was something like operating in power saver mode. Car will not go over 30mph, unless it's rolling downhill. Limped the car to an open GM dealership. Here we sit. Has this happened to anyone else?
I have not had any battery issues thus far, I wouldn't think a battery would die from only three and a half hours of headlights on. hopefully the battery was going down hill and that just pushed it over the edge, and the fix is as simple as a new battery. Good luck and let us know how it turns out.
Dead Battery
OK, As posted above by my friend while in Ohio today. We went to the Canfield Swap, got there around 9AM. Walked away with the lights on, about 3 hours later he returned to but our load in the back. Key fob would not work, so he opened the drivers door with the key, reached in to unlock the back door to put all inside.
He returned and was telling me about the fob not working ??? Did not give it a second thought. Till we came out to leave, found that I had left the lights on !!
We do not recall hearing a chime warning that the lights were on. Plus I thought there was a low votage shut off in the system ??? if there is it did not work.
We got a jump and got her started, but she was only running on low engine operation according to the dash read out. After driving it about 6 miles on a super highway we made it to a dealer. We waited about 2 hours before they got it into the shop. Then it only took 15 minutes to recode the computer to operating spec's. Drover home at an avg. speed of 75 with out missing a beat.
I'd like to ask everyone to turn on the head lights with the key off and tell me if you can hear a buzzer or bell ??????
Next, does any one know if there is a shut off if you do leave the lights on after about 20 minutes automatically ?????
I'd also like to know, say your HHR is rear ended and the battery is smashed and you have no power. Know will the windows go down, key on but no battery power left ???
And will the door locks work with the fob ??? I know alot of us have installed those smoth door lock's. Say you are driving and the battery is smashed, shifter is in gear or you can get it into park ?? How do you get the doors unlocked ???? to get out ??? Just think it a little furthur and the HHR is on FIRE ??? How do you get outin a big rush. Oh, you do not have the tool to smash the glass to crawl out ??????
Just think about it !!!!!!!
How did you jump start the HHR? Under the hood posts?
Location: Superior, WI - Over the Hill Warranty Club member
This is a feature lots of people are not used to, but Had this on my 2000 Grand-Am also. Why not let them turn on and off by themself, been doing that for almost 2 years now.
