Do you have this problem: Key Won't Unlock Door
Thanks...sorry. I thought you guys were with GM...
Anyway, tow company got me in. After testing, it turns out the electric lock on the inside was causing the problem. Found if I use the key to lock/unlock it works. Realize now it must be the motor. I'm pissed because GM decided to wire all the doors through a single circuit that must be run off the drivers side. So when this goes, no way to get in. Cost me $55 and I'm not going to repair it.
Than ks for your reply and apologies for my rant...
