Pulling to the left ?
Old 06-06-2012, 12:50 PM
dustin6119's Avatar
replaced rotors and going to re-balance the tires today....in lew of that what else could be the issue.....and also a light vibration???? all comments and theories welcome.....just as to save myself a little time when trouble shooting....please keep in mind I have been driving a JEEP TJ for the last 5 years..LOL
dustin6119 is offline
Old 06-06-2012, 01:12 PM
solman98's Avatar
Sounds like tires or an alignment.
solman98 is offline
Old 06-06-2012, 01:33 PM
x2 - inspecting the tires for uneven tread wear or damage (ie: broken belt internally - spin wheel/tire on the car, looking for wobbles etc in the tread), then swapping tires would be my first step at diagnosing the problem.
A light vibration would make me suspect a damaged or delaminating tire if the balance is ok.
whopper is offline
Old 06-06-2012, 03:25 PM
badassbowtie's Avatar
how bad is it pulling left? a little is normal to offset the pitch of the road
badassbowtie is offline
Old 06-06-2012, 03:28 PM
X 4
843de is offline
Old 06-06-2012, 03:38 PM
LawDog88's Avatar
For the pull to the left, it sounds like alignment or bad tread wear.
The light vibration, is it in the pedal or the steering wheel?
LawDog88 is offline
Old 06-06-2012, 03:58 PM
Snoopy's Avatar
I don't believe this is true. Unless someone specifys it, it is not INTENTIONALLY done by the factory or a front end tech.
Think about it....what happens when the pitch of the road goes the other way.
Snoopy is offline
Old 06-06-2012, 04:17 PM
bigjacksauto's Avatar
How many miles?
is it drifting or pulling to the left?
At 65 mph how long would it take to start crossing the lines in the road?
I would check tire pressure first.
Then I would swap the front tires side to side as long as they are not directional.
to see if you are getting radio add l tire pull.
Then have your alignment checked.
If all that checks out have a gm tech check ed checkout the intermediate shaft and
Steering column.
I know some will doubt this but my car was pulling left.
changed tires side to side helped a little.
Then had two alignments done which helped but still was not right.
Had a clicking in the steering. Column was bad
After the tech replaced it it has been driving like a new car.
I myself would not have believed a worn out steering column would for this.
bigjacksauto is offline
Old 06-07-2012, 09:03 AM
dustin6119's Avatar
OK rebalances tires they check OK
however the mounting on the direction is not correct so that will be my next step.....
wheel bearings and tie rods Check OK
balance Checks OK
gimme a few days to track this down and Ill get back to you
Old 06-07-2012, 09:25 AM
solman98's Avatar
Do you mean directional tires mounted backwards? If so, that still shouldn't affect normal driving, just not the best handling from the tire.
solman98 is offline
Quick Reply: Pulling to the left ?
