Noise Under dash-Brake Pedal?
Old 08-25-2010, 01:49 PM
dbranga's Avatar
Question Noise Under dash-Brake Pedal?
I just started getting a noise under the dash right near the brake pedal. A psssssssssssssssssss like air leaking. A couple taps on the brake pedal and it stops. I happens 95% of the time I use the brakes. It has even happens when I turn the car on for the first time in the morning. The car brakes fine, I haven't noticed any difference in pressure with the pedal. Any ideas?
dbranga is offline
Old 08-25-2010, 11:17 PM
IgottaWoody's Avatar
Booster leak...coming thru the brake rod.....just vacuum....warrenty
IgottaWoody is offline
Old 08-26-2010, 06:21 AM
dbranga's Avatar
Thanks Woody. It's a 2006 with 84,ooo miles on it so I am out of my extended warranty. Any one know how much this repair might cost? Is it a safety hazard?
dbranga is offline
Old 08-26-2010, 10:18 PM
I'd first try to verify it..like shut down motor and right after hit brakes and see if its still there, you'll hear it better(radio,fans etc off of course) then start junk yarding it...everything else is bolts if your mechanically inclined.Othewise you could keep going if its not annoying, if it gets really bad you'll notice the brake feel going hard....
Though, you say that hitting the brakes stops the noise..hmmmmhow long will it hiss if you just sit there?
Old 08-27-2010, 06:11 AM
dbranga's Avatar
I've heard it hiss for up to 30 seconds before I finally tapped the pedal. Other times it won't hiss at all.
dbranga is offline
Old 08-27-2010, 10:41 PM
Welp....boosters dont have but a few parts with the diaphram being the main deal, so start preparing. About $50 for an A1 Cardone booster plus core charge at Racepages.com....other then access space they are really not that hard to change out..just have to be careful handling the master cylinder, some have to be removed and some don't. Unless you have ABS bleeding the brakes is straight forward too if you need to remove the mc. Try to snag a manual someplace and read up before you try to tackle it or maybe decide to let the "shop" handle it. Your ok for now but if you ever start to get a steady hiss its time, if you lose the booster you do not lose brakes, you just have manual brakes.
Old 11-15-2011, 10:27 AM
dbranga's Avatar
Anyone have any idea wht this might cost to repair??
dbranga is offline
Old 06-14-2012, 06:36 PM
dbranga's Avatar
turned out to be the brake booster after all. finally fixed it after 18 months, not because it failed, the noise was just getting to be to much. of course, fix 1 thing and something else goes - had to replace the front struts a month later! still, not bad for 116k miles on it.
dbranga is offline
Old 06-14-2012, 06:47 PM
VinceP's Avatar
116k for front struts is excellent as far as I am concerned. Mine started weaping oil before 50k. Just replaced them at 80k and both they and the rear shocks were just paper weights by then. Glad you got everything fixed.
VinceP is offline
arttysHHR
11-13-2010 11:11 PM
jcmorehead
12-29-2009 06:10 PM
andoll83
04-01-2009 07:14 PM
rocko54
7
03-08-2009 12:24 AM
xzombiex66
03-28-2007 05:44 PM
Quick Reply: Noise Under dash-Brake Pedal?
